fleetwoodjambo
Aug 02, 2018Explorer
That’s impressive, thanks for the insight. I’m not as mechanically inclined as you appear to be but that gives me an idea. My 460 in fuel injected and the portable water tank in under the couch which is located behind the drivers seat. I think I would only have to run it about 10 feet to reach the radiator. I’m going to get underneath it and see what this would require to install. There is already a hole in the firewall for fuses and plastic wire casing going to the engine, so maybe I can squeeze some pvc pipe in there versus drilling new hole. Any other issues you had with the 460 besides heat?
38,764 PostsLatest Activity: Dec 25, 2025
