TJHUB
Feb 26, 2018Explorer
jerseyjim wrote:
Good advice above, I can only add something regarding the lack of 110 in the bedroom outlets:
I have a 2001 Dolphin which is, I think, 1 step above the Seabreeze. For whatever reason, NationalRV had the very front outlets (TV and coffeemaker outlets) on the same circuit as the 2 bedroom outlets. They were controlled by the INverter. (Not to be confused with the CONverter) Presumably you have an INverter. If you do, check the circuit breaker on that. That could be your problem.
((Note: last fall, my INverter failed, and seeing I never used it, I removed (bypassed) it. Everything works fine, I just have to remember not to put any really heavy draws (like a space heater) on those outlets. No biggie.))
Stay with Fantastic Fan. Excellent customer service. So is their product.
G'luck!
I will work on understanding the systems to help figure things out. The only breaker panel I check over quickly was the one below the slide out panel. I didn’t find any obvious issue there.
38,707 PostsLatest Activity: Jan 05, 2014
