Tom_Anderson
Nov 18, 2022Explorer
It definitely sounds like brakes to me. It seems to be at wheel speed, not driveline speed, so I doubt it's a u-joint or carrier bearing.
Can you jack it up when it's cold and rotate the wheels? Ideally, you would put the rear on jackstands and run it while it's stationary to see if you can hear it while you stand outside. Then you could hopefully identify where it's coming from. Unfortunately, most people don't have that capability.
Have you ever replaced the brake pads? If not, I'm thinking it might be about time.
38,765 PostsLatest Activity: Jan 08, 2026
