For those of you that have taken the time to re caulk your RV windows did you remove the window frames or just re caulk along the outside edging? Thanks for your input.
Mine is almost 20 years old. I had no leaks but just for PM I put a small bead of clear around all tops and sides of every window a couple of years ago and still no problems and you can't even see the caulk.
