MountainAir05
Aug 28, 2016Explorer II
Re: CB Radio antenna mounting
http://www.firestik.com/CatalogFrame.htm
click on No ground plane and you get three mounts. No you can not run a ground a get much from it. Click on 3 way mount. DO NOT CUT the cable that comes with it. The cable is the ground plane and is tuned for the antenna. You also need to do a SWR adjustment on the antenna build in knob.
There are short antennas about 18 inch that plug into the back of the CB, but only good for a short distance.
