Re: Chassis battery disconnect
No it will not cause damage, disconnect the black cable first, then the red one if you want to, when connecting the red goes first and then the black one.
If you live in a smog control area, you will need to drive the RV for at least a half an hour so that the computer regains all of the parameters of the engine, other wise it will fail, not because of smog but the lack of sufficient sampling for the computer's memory.
navegator
No RepliesBe the first to reply
