T-Rex
Jan 27, 2021Explorer
klutchdust wrote:
Try posting the issue on BAT auto and a Ford truck forum. Your issue is the fuel/air mixture on a cold start. Post what you wrote on BAT, they have helped me in the past with real brain teasers.
This has to be dealt with methodically. As mentioned, contact cleaner ,not brake clean ,can really help.
Also once codes are cleared remove battery power to engine, it has an effect on the computer systems to reset. Kind of like what you do to your desktop.
Sounds like a good tip to try. Will do. Thanks.
38,776 PostsLatest Activity: May 14, 2026
