DAWg134
Jan 11, 2016Explorer
If you have a dual battery setup (i.e., vehicle battery and coach battery), then it is possibly your battery separator cycling on/off. As the battery you are charging reaches around 13.6 V, it'll come on, thereby connecting the two batteries together. As the second battery (at a lower voltage) drains the current from the first battery, the separator will switch off somewhere around 12.6 V. The clicking noise is the relay contacts either making or breaking the circuit.
38,766 PostsLatest Activity: Jan 10, 2026
