freekie
Nov 11, 2017Explorer
I have a 2017 32 foot leprechaun 319mb. My Water heater bypass valves are right behind the water heater. Remove the panel under the stove or under the fridge you should see 3 valves there.
The low point drains are under the shower floor. Remove the panel to access them. Then theres 1 more valve at the fresh water tank to shut off. Now your ready to suck anti freeze in from out at the water hook up.
Hope this helps
Jim
Hope this helps
Jim
38,769 PostsLatest Activity: Mar 29, 2026
