11178adm
Nov 30, 2020Explorer
there aretwo power sources to the ecm one is from the ignition switch and the other is unswiched ( hot all the time ) usually connected directly to the starting batterys this wire will have a inline fuse ussually in the battery box make sure it's not blown. if you had the cables disconnected did ths wire get reconnected a quick check to verify the ecm is powering up on initial key on the check engine and stop engine light should cycle on and off if they don't either the swiched or unswiched power is missing
hope this helps
hope this helps
38,713 PostsLatest Activity: Apr 08, 2025
