jorbill2or
Oct 06, 2023Explorer II
Oil fills are in the same general space drivers side up high on the front of the engine. Accessible via the front “hood” grill. The only issue is it’s up so high with no room to tilt a 21/2 gallon jug you might find it easier to put the 8qts in with a pump. There are lots of cheap fluid pumps out there. I have a cheap 2D battery powered one I use.
38,764 PostsLatest Activity: Dec 23, 2025
