jmd87
Sep 07, 2015Explorer
2bzy2c wrote:
I have done many 440 water pumps. Easy. If you can rebuild a carb., the water pump should be a walk in the park.
Thank you for posting the results. It helps all of us learn.
Hi,
I was hoping for a bit of advice from you if that's ok?
Basically I went up to the RV and tried to remove the water pump. I can't seem to get the radiator out at all! It seems to be in a surround which is bolted to the chassis which I've undone and have undone all the hoses etc but the radiator won't move at all.
Am I doing something stupidly wrong here? Do I even need to remove the radiator?
Kind Regards
Joe
38,782 PostsLatest Activity: Aug 31, 2026
