Old_Snipe
Jan 11, 2014Explorer
I installed the primer pump on my 07 WB Journey 39K. Plenty of clearance to install it.
When I change the filters, I change the water/separator filter first. I used the primer pump and fill it. Then I start the engine and let it run to get any remaining air through the system. I then replace the secondary filter up on the engine block, fill it with the primer pump and start the engine.
Doing it this way is easier because I don't have to pump the pump handle as much.
Best Regards!
Best Regards!
38,771 PostsLatest Activity: Apr 19, 2026
