dougrainer
Dec 05, 2023Nomad
I am not familiar with your model. BUT, I have 45 years as an RV tech. MY FIRST impression when a customer has your problem and there are NO leaks on the ground or in the RV, is indeed a possible pump, especially over 15 years old. BUT, do you have a City water, water tank fill valve? Most RV's (motorhomes) do. The 2nd option I look at when your problem happens is the City water tank fill valve is leaking internally and the pump is just cycling and putting water back into the tank. Shurflo builds an excellent Pump, The odds are to get a new pump with the same problem is extremely rare.
38,768 PostsLatest Activity: Nov 21, 2015
