truepath
Jan 22, 2015Explorer
The first thing I would look at are the tires and it sounds like you have done that. I hope you installed light truck tires NOT car tires. Years ago when I got my first van, the previous owner had installed car tires. I suppose that seemed reasonable since they came in the correct size and were inexpensive, but the handling was terrible. I could not believe the difference when I installed proper tires. After eliminating (or correcting) tires as the source of the handling issues, I would take a look at adding some kind of rear suspension enhancement. I have used helper leaf springs which really did help, but better yet is a rear air bag system which helps more. Finally, you might consider a "Safe T Plus" type steering control system which really amounts to a large shock absorber that connects to and stabilizes the steering system. I have one on my Dodge Leisure Travel Van and it makes a difference. Beyond all of this, high profile vehicles are inherently going to be more susceptible to side wind loads than other vehicles. Driving slower in windy conditions is usually required.
38,765 PostsLatest Activity: Jan 07, 2026
