Tioga76
May 28, 2009Explorer
79powerwagon wrote:
I doubt your oil burning will have an affect on your test results. There are a million 90's Caravans around here with the Mitusbishi V6 that are notorious oil burners that look like a James Bond movie scene that regularly pass the same sort of test.
And, it was 1973 (for cars) when unleaded fuels started.
I can't believe you have to have a 1 ton truck tested. But since you do, go in with the fresh oil change (that morning), make sue the engine is at operating temp (drive around at least 40 minutes before the test, all in one trip, have fresh gas in the tank, and see what happens. If you fail, you'll know what you need to do (usually a tune up adjustment is all that's needed) and we can go from there.
Ironically, the MH passes the emissions part of the test just fine (HC, CO, etc), but then it fails because of visible smoke. I guess in Colorado you can't get a waiver for smoke either, regardless of the cost to repair. But if it was polluting real bad, like high HC, I could spend a couple hundred bucks on repairs and if it failed again I could get a waiver. Go figure. I had a 93 Dynasty with the Mitsubishi V6 that made so much smoke I could barely see the car behind me. Passed every time.
Anyway, enough about the emissions test; I have to do it so I will do what I can to fix the smoking and I will try again. Thanks everyone for the information and advice on my problems.
38,768 PostsLatest Activity: Jan 26, 2021
