winepress
Mar 15, 2016Explorer
dougrainer wrote:bullydogs1 wrote:
Doug
I value your wisdom and knowledge but my friends IOTA switch heated the contacts and a burning smell ensued...enough to scare anyone..that's why I called it a ticking time bomb.
It was the LOOSE connections that caused the problem, NOT the Iota. Doug
If you use this transfer switch(IOTA)you need to periodically check the terminals. The problem is the terminal bar, it is made from aluminum and the wiring is copper, which is not a good mix. Add that the enclosure is made from plastic is another problem. Tick, Tick.
38,782 PostsLatest Activity: Sep 10, 2026
