wa0mqe
Oct 03, 2010Explorer
Lobstah wrote:
Bob,
Was this fix referring to your basement doors, or your main entry door?
My weather stripping has now "rolled in" all the way around the door, and it's very difficult to close, so it's moved up to the top of my list now.
Jim
Jim, the weather stripping I referred to was for the outside compartment basement doors.
Speaking of the main entry door, it started catching as we closed the door. Ends up the heads on some of the rivets that holds the door to the frame had come off. Mostly up toward the top. This caused the door to sag and catch on the bottom. I drilled the bad rivets out and used some good stainless steel sheet metal screws to pull them back to the frame. So far so good.
Not sure if this will help but take a look at this web site for some weather stripping. They appear to have some good choices for stick-on weather strip. Much better then what you can get at Home Depot/Lowes, etc. When you get to the web page click on the "Peel-n-Stick" logo towards the center. Weather Stip
38,765 PostsLatest Activity: Jan 08, 2026
