abrasv
Jun 05, 2013Explorer
Dennis, I tried to post a pic but can't get it to show up. What I did was remove the screen on top of the vent and mount the 4 fans to a piece of plywood with a cutout for the fans. Originaly I was going to mount them farther down in the vent but this looked simpler and just as efficient. After screwing the assembly down I ran a bead of caulk down the sides of the plywood to completely seal the top. Drilled a few holes in the plywood to allow venting from the lp when it runs.
I wired it to a switch I installed by the fridge so it can be controlled manually. When I flip it on and hold a paper towel next to the outside vent it holds it tight against the intake.
I'm a happy camper:C
38,766 PostsLatest Activity: Jan 10, 2026
