Rollnhome wrote:
Gasman I probably should have said monitors "Available" air for air ride system. But in simple terms it monitors air ride air. If it goes to zero so does your ride.
. The air pressure in the air ride system will only change if the ride height control valve calls for move or less air pressure to maintain ride height. You can drain all of your Air tanks and the pressure in the air ride would remain the same if the ride control black valve does not move. Of course over period of time the air system will leak off depending on how tight the system is. Rollinhome what is the reading on each of your air gauges when the air system is air up? I'm betting they are nearly the same. The air pressure on my tag is 40 lbs not even close to what my air gauges indicate
