Handbasket
Apr 03, 2015Explorer
If you can get it onto a lift, replacing the voltage regulator in an underslung Onan Microlite 2.8 or 2.5 isn't hard, just patience-& dexterity-challenging, blindly feeling for a small tapped hole in the base pan that has NO lead-in or countersink, with the end of the screw. That's a real, real PITA (mine have only had one, a Torx).
Replacing the VR on ramps or the ground might be beyond all but the slimmest & most flexible. Dropping the generator _might_ be worth it, but all you achieve by having the cover off is a slightly better working angle accessing that dam'd screw hole.
You do need some minimal electrical savvy & a multi-meter to go thru the troubleshooting steps outlined in the Onan manual or on the Flight Systems website. I'd be darned sure that's what the issue was before buying one and going to the pain of replacing it.
Jim H.
Jim H.
38,709 PostsLatest Activity: Mar 12, 2025
