DoubleVeteran
Jun 29, 2017Explorer
Quick update:
OK, I removed the awning and found that's it's not carriage-bolts or screws that hold the mounting brackets, but pop-rivets. Each bracket is pop-rvieted from the outside with 3 each pop-rivets; makes sense since I don't see anyway to run bolts from the insde, which would be much more secure.
So when I tried to roll it all the way out (as the dealer showed me...), it popped the heads off the pop-rivets. I will be doing the walking-out method once I get this fixed in the future.
So to fix, I plan to drill out what's left of the rivets and install new ones. The rivets go through the bracket, then a metal spacer (secured in some way to the fiberglass topper), and then into the fiberglass topper, so I need to make sure I get the right rivet type, thickness and length. I'm definitely open to any advice for the reinstall.
Thnx for roll-out advice and help!
DV
DV
38,716 PostsLatest Activity: Apr 27, 2025
