tomcat88
Mar 22, 2023Explorer
This is a problem on all E-150 thru E-450, the Ford dealer wanted $1500. to $2000.00 to fix my 04 E-450, So I check out some You tube videos and went to NAPA pick up some good rubber vacuum tubing and vacuum control valve for the AC, took me 45 minutes to do the repair. No I did not remove the right inner and outer fender, all of the dash like Ford would, only the grove box and dash cover under it. I was 77 when I did the repair,
38,768 PostsLatest Activity: Jan 26, 2021
