Rich_D_
Oct 02, 2013Explorer
Since I was purchasing tires, I opted for the type that has internal sensors. They work great, are invisible and theft proof. Simply mount the sensor onto the rim with a long hose type clamp. Then mount the tire and balance as usual. The sensor and clamp weigh next to nothing so there is no need for extra balancing. I'm sure there are many good systems. The one I choose was Tire SafeGuard. You can mix the internal sensors with screw on for the toad if you wish. They also make an internal stem mounted sensor. If you have an all steel body vehicle such as mine, be sure to get the "N" type monitor as some of the others may not pick up the signals properly.
http://tiresafeguard.com/
38,763 PostsLatest Activity: Dec 26, 2025
