Son_of_Norway
Apr 28, 2023Explorer
Seems like a fuel supply problem. Are you keeping the gas tank full? Maybe your fuel pump is overheating. I had similar problems and had to drop the gas tank several times to replace fuel pumps. I finally had enough. I installed an external fuel pump 2 years ago and I've had no problems since. If the external pump does go bad I can replace it in 20 minutes. I also replaced the wire going back to the fuel pump. There's too much voltage drop in the 30 feet of 16-gauge wire that came from the factory. I'm surprised that the original pump lasted as long as it did. The replacement pumps these days don't last anywhere near as long.
38,768 PostsLatest Activity: Nov 21, 2015
