atreis
Oct 24, 2021Explorer
jukes wrote:
considering downsizing. currently have a 2007 30' TT with the Queen bedroom and 2 sets bunks. These days it's usually just 2 adults and a 9 year old, the teenagers aren't so keen. But I've got used to space lol. Plus our 7.3 Excursion tow vehicle is getting old :)
Would like a smaller MH
Not sure what "smaller" means in this case, but you should be able to get something in the 24-28' range ...
jukes wrote:
but that can tow our old Boston Wailer boat. Also able to carry 3 or more bicycles.
Boston Wailers aren't very heavy, so this part is easy. Nearly all Class C RVs can tow 4500-5000 lbs.
jukes wrote:
Also want a separate full or queen bedroom area, plus another twin or full bed that can have a nice mattress (so not a couch pull out etc). The area above the cab is usually pretty small and awkward right???
Depends on what you're looking at, but in most traditional Class C RVs the cabover is larger than a queen. About the same width, and longer. They're very sizable. There are some smaller units on MB chassis that make the cabover smaller.
jukes wrote:
Plus another bed suitable for a growing 9 year old..
Which MH's have this, good use of space? Best bang for the buck!? Thanks!!
My unit has 4 sleeping areas and is 28' (model name does not equal length). Queen bed in the back, dinette, jackknife sofa, and cabover. It works VERY well for my family of 5 - 3 teenagers (two in college). Just about any unit you look at is going to have similar options... Shorter than mine, and you'll likely lose one of those sleeping areas, such as the sofa, but would still have 3 sleeping areas.
There are LOTS of options from MANY manufacturers... Winnegabo Minnie Winnie, Thor Four Winds/Chateau (what I have), Coachmen, and many more. Just look around some, but starting with those will give you an idea of what floorplans offer.
Things to watch out for:
1. The number of belted seating areas for travel. Some units don't have a lot of belts. In particular, seating areas that are mounted on a slide are often very limited on belts.
2. The LENGTH of the sofa and/or dinette bed, relative to the height (and potential height) of the kids. In some units, the dinette and sofa beds are very short.
3. Whether or not you're okay with having a sleeping area that can't be used if the slide is in (such as the rear queen in mine).
38,776 PostsLatest Activity: May 14, 2026
