jackie
Aug 22, 2019Explorer
rgatijnet1 wrote:
I'd be concerned that the adjustments you made affected the alignment.
I know quite a bit about suspension. The Roadmaster Front Suspension is really simple. The actual steering parts consist of a drag link that connects the steering box to the driver's side hub steering arm, and then a tie rod that transfers this steering motion from the driver's side hub to the passenger side hub. This tie rod also adjust the toe in or out of the front wheels.
“Alignment” is done at the axel, which is a I-Beam with a Panard Bar. It features a Panard Bar because instead of leaf springs, there is a link Suspension supported by air bags.
So, that being said, how could what I did, (making the Drag Link adjustable in place), affect the “alignment”.
38,769 PostsLatest Activity: Mar 31, 2026
