Re: Thor Majestic Cruise America 19G on-going Q and A
Let me start with the first question.
I have a question about the little seat next to the main door entry to the right if you are stepping into the cabin area. I have seen in a video where someone is able to access whatever is under the seat cushion by pulling out the back pad then pulling off the cushion itself.
However, as much as I try, that seat back isn't moving, at all. Clearly I am missing something here...is it bolted down somewhere? Is there some secret methodology required to pull it up/out. Do I have to remove the lower curtain rail?
What's the trick?
No RepliesBe the first to reply
