KK_R
Oct 17, 2014Explorer
Az Kid,
Could you clarify in less technical terms what you refer to as " all the screws holding the ground wires on the bus bar." I'd like to do this, but bus bar is not a term with which I am familiar.
Also, by "wires going to the breakers," do you mean the wires that end up in the breaker/fuse box behind the sheet metal housing the converter? So you mean just tighten their connections with a screwdriver? Clarification appreciated.
38,782 PostsLatest Activity: Sep 10, 2026
