Ed_CExplorerMar 06, 2021Re: Tire pressure and temperature recommendationsYou need to know the weight...at each corner or at least each axle. Then you can check the tire manufacture's chart for those weights. If the tire pressures are right the temperature doesn't matter unless it changes drastically
Related ContentDealing With Coolant System Pressure and TemperatureTire pressure (temperature) increase while drivingTire pressures during temperature swingsWater Heater Replacement RecommendationsRecommend Tire Pressure
