BigToe
Oct 31, 2022Explorer
pnichols wrote:
That's good data above in your post.
However it raises one important question rarely discussed in any of the forums:
For a given tire size between the two tire types that the C-Metric version is a more rugged/stronger tire?
i.e. That the C-Metric version has more plies? If so, if carrying capacity is not an issue ... should one use the C-Metric type tires if they wish for more puncture-proofness - as in occasional offroad travel with their Class C?
SJ-Chris wrote:
To me, yes...it means the Commercial rated tire is stronger and thus less likely to have a blowout.
Would anyone like to share the downside of getting Commercial rated tires at least on the rear? The cost (in my experience) is minimal.
Chris
The potential downsides to getting a C-Metric tire depend on the brand and model of tires being compared.
But first, to clarify, the term "C-Metric" is used instead of "Commercial", because there are a plethora of Commercial tires in the LT-Metric size and Load Range E rating that are not C-Metric.
To suggest that only C-Metric tires are "Commercial", whereas tires in the same size without the appended "C" after the rim diameter are not, does not properly reflect the long standing tire offerings available in North America for decades prior to the importation of Euro Vans, beginning with the Sprinter, and continuing with the Fiat (Ram Pro Master) and Ford Transit.
In Europe, these Euro vans are fitted with tires specified by the European Tyre and Rim Technical Organisation (ETRTO), which developed a Commercial tire standard to distinguish tire characteristics from Passenger car tire standards.
We have the same distinction in North America, where we have P-Metric passenger car tires, and LT-Metric light truck tires. "C" is to Europe what "LT" is to the United States. It isn't as if an LT tire is not a commercial tire. And it certainly isn't as if to get a "true" commercial tire in the United States, one must look for, or insist upon, a tire size appended with "C". That is not the case.
None of the Commercial tires on Peterbilts, Kenworths, Freightliner Medium and Heavy Duty, Navister International light, medium, heavy, or severe duty trucks use tires that are C-Metric. Does that mean that these trucks are not specified with "Commercial" tires? Of course not.
The same holds true for 3500/4500/5500/6500 and 350/450/550/600 trucks from the Big Three domestic pickup and chassis cab manufacturers. These trucks are specified with commercial tires that do not have "C" appended after their rim size. In otherwords, they do not use C-Metric tires. But they do use Commercial tires all the same.
Some examples of LT-Metric Commercial tires include, but are not limited to,
Americus Commercial LT All Season Tire -
LT225/75R16 115Q LRE 10 PLY
BFGoodrich Commercial T/A All Season 2
LT225/75R16 115/112R LRE 10 PLY
BFGoodrich Commercial T/A Traction
LT225/75R16 112Q LRE 10 PLY
Bridgestone Duravis R238 Commercial Summer Tire (LRE)
LT225/75R16 115R LRE 10 PLY 14/32nds 50.5 lbs. $311 Steel Sidewall Casing
Bridgestone Blizzak LT Commercial Winter Tire (LRE)
LT225/75R16 115R LRE 10 PLY 17/32nds 36.9 lbs. $204
Bridgestone Blizzak W965 Commercial Winter Tire (LRE)
LT225/75R16 115Q LRE 10 PLY 17/32nds 42.5 lbs. $144
Bridgestone Duravix M700 HD
Firestone Transforce HT2 Highway Terrain Commercial Light Truck Tire
General Grabber HD Commercial Truck Tire
In creating the list above, I simply worked my way through the alphabet, and grew "tired" of adding tires to this list by the time I reached letter G in the alphabet. And I didn't even cover all of the tires available by brands beginning with A-F (Falken just came to mind as I type this), but it seems certain that if I made it as far as the letter "G" without mentioning Goodyear, the Goodyear Blimp will probably dump their holding tank over my house next time they go floating by, so let me add the following two tires to the list:
Goodyear Endurance RSA ULT 16"
LT225/75R16 115Q LRE 10 PLY 50 lbs
Goodyear Endurance RSD ULT 16"
LT225/75R16 115Q LRE 10 PLY 49 lbs.
These Endurance tire casings are so tough, Goodyear states that they are re-treadable. Not that this means a hill of beans to owners who time out their tires before they wear out, but still, the Endurance RSA ULT is in Michelin XPS Rib and Bridgestone R238 territory.
Lateral scrub-resistant tread compound
Premium enhanced casing
Reinforced shoulders and steel-steel belt package.
All of the foregoing are Commercial tires, listed for last mile delivery, school bus, emergency services ambulance, urban utility, etc.
Hence, to distinguish the Euro Centric designation for the 225/75R16C tire, the "C" shall be referred to as "C-Metric", which is Europe's near equivalent to what in the USA is called LT-Metric.
There are no downsides to getting commercial tires, as there exists enough variety among commercial tires available in North America, whether designated as LT Metric or C Metric, that the plethora of alternative choices effectively cancels out any downsides.
So to focus only on any downsides of getting "C-Metric" tires, one has to consider the question brand by brand, where a given tire brand may make an 225/75R16 in P-Metric (out of the question), LT-Metric (as specified by Ford, the E-350/450 manufacturer), and C-Metric (as recently applied with tires specified for Euro vans).
Some tire brands don't even offer a C-Metric tire in North America. Moving up a letter in the alphabet to "H", consider Hankook. Ford specifies and equips new E-350 and E-450 cutaway motorhome chassis with the Hankook Dynapro HT LT235/75R16E tire as standard equipment.
Every year it seems, Ford works with Hankook to tweak the specs on this tire. The details of the changes are propietary, but the evidence that changes have been made are found in the material product code. Currently, the following product codes for this tire might still be available at any given tire distributor:
2021163 (36 lbs)
2020873 (39 lbs)
2020694 (39 lbs)
2001831 (40 lbs)
If one were to take delivery of a 2023 Model Year Class C motorhome built on a Ford E-350/450 cutaway chassis today, then the standard tire would be the 2001831 material product code of the Hankook Dynapro HT LT225/75R16E LRE tire.
UNLESS... the motorhome manufacturer took advantage of Ford's FIN option to have Michelin Agilis Cross Climate tires fitted instead. Unlike Hankook, Michelin offers the Agilis Cross Climate tire in both LT Metric and C Metric variants.
However, Ford will only supply the LT-Metric variant on the E-350/450 cutaway, if the ordering fleet specifies (and pays for) that option.
This post is getting long in the tooth, and may soon reach the character limit, so I'll stop here and examine the Michelin Agilis Cross Climate comparison between the LT225/75R16 versus the 225/75R16C in my next post.
38,766 PostsLatest Activity: Jan 29, 2026
