senf
May 11, 2013Explorer
Blow out the lines, open the fresh water tank drain valve, use pink antifreeze in the "P" traps, the toilet, grey tank and the black tank. Drive around for the fresh water tank to empty completely. Any non-treated water left will expand harmlessly on freezing.
All of the above anitfreeze is contaminated and should not be re-used.
Re-sanitize your lines and fresh water tank with a mild solution of bleach before next use. Filter the water you use to fill your tank or through the shore connection.
38,782 PostsLatest Activity: Sep 10, 2026
