- lucytravel12ExplorerOne more thing - how do you dispose of the pink stuff?
- lucytravel12ExplorerI didn't blow the lines; didn't even think about it being diluted. I'll definitely get it at ACE next year - thanks.
- pianotunaNomad IIIHi,
I reuse mine. I blow the lines, then install, and then immediately blow the lines again saving the antifreeze. I often winterize seven times per year. - gboppExplorerYou can use it. It will be diluted. How cold does it get in Louisville KY? You may or may not be okay depending on the winter temperature.
- tmmarExplorerIf you get it at Ace hardware in the fall, they usually have it on sale for $2.99 a gal with a $1/gal rebate on up to 3 gals.
- Jack_Diane_FreeExplorerAgree it is probably diluted. Why chance it to save a coupla bucks.
- TrackrigExplorer IIIt depends on how much it bacame diluted. If you poured one gallon in, there was probably about a gallon of water in the traps, so you may have diluted it by 30 - 40% already. I wouldn't take a chance on it to save $3.75.
Bill - phillygExplorer III think you can, but jeez, it's cheap stuff.
- 2oldmanExplorer IIya
38,782 PostsLatest Activity: Aug 23, 2026
