Guyver280z
Jan 15, 2014Explorer
Ok,I found some info on this Beaver Contessa:
Gross Vehicle Weight Rating 34,600LBS
Gross Combined Weight Rating* 44,600LBS
*Towing capacity is limited by GCWR; your vehicle's towing capacity is the difference between the GCWR and the actual vehicle weight, including all water, fuel, passengers and cargo. Your towed vehicle should be equipped with auxiliary brakes if the weight of the towed vehicle exceeds 1,000 lbs.
Which means this beast is capable of towing a 10,000LBS trailer, right?? And I think my trailer with the cars is not going over 8,000LBS, so something like this should be good enough, right??
38,769 PostsLatest Activity: Dec 31, 2017
