Chris_F
Jan 03, 2015Explorer
PawPaw_n_Gram wrote:
I am not really finding a typical UVW or Empty Weight listed in the specs of almost any Class A or Class C - from low end to million dollar DP units.
GVWR, GCWR and Axle Loads are about all the weights I can find.
These vehicles are subject to similar weight reporting regulations as those for cars and trucks. The Vista Manualshows the "Occupant and Cargo Carrying Capacity" label required for all Class A units on page 1-3. The carrying capacity is dependent on what options are included, so you won't find a "general" UVW value
Note that there is an additional label required if the anything weighing more than 100 pounds is added by the dealer. The regulations are pretty tight!
I have found the OCCC's for the coaches I am interested in by looking at the labels in the actual units. If you can't find a 27N nearby, you might be able to get the information from Winnebago if you specify the options.
38,768 PostsLatest Activity: Jan 26, 2021
