Re: Winter time travel
It takes a lot of very cold to do any damage to an RV. I assume your Navion came with heated tanks, and a 30,000+ BTU furnace so you should have no issues there. As long as the temps don't get below the mid 20's for an extended period of time nothing should freeze.
Keep a few cabinet doors open so the heat from the furnace can circulate. If you are comfortable then your plumbing should be good. Warm up the coach well before retiring and you will be fine.
No RepliesBe the first to reply
