wd's avatar
wd
Ready brake
Has anyone set up a ready brake break away on a 2005 TJ Wrangler? Looking for the best location to mount the red box.
Thanks for any help.
  • I finally made an L bracket and bolted it to the front lower part of the Jeep. Thanks for the replies.
  • If you don’t have abs on the rig, there is a tray on 5he drivers fender liner, did our braking system there on our 06
  • I had a 2006 TJ. Its been a number of years, but as I recall my TJ had an extra battery tray near the steering column. I didn't have an extra battery so my extra battery tray was empty. There was a bolt in the rear of the tray that wasn't too far from the firewall where I had run the ready brake cable to the break pedal arm. I used an L bracket bolted to this bolt on the extra battery tray. I bent the L bracket slightly and bolted the emergency break away box to the L bracket and was able to run the break away cable through the firewall to the brake pedal arm. Hope this helps.
