93mastercraft
Mar 24, 2015Explorer II
Some will say there is a lot of loose movement with the Ready Brute. My video will definitely show this. I was more interested in seeing how the Road Master base plate would work. I just installed this one my new Jeep Wrangler unlimited. This time I went with the Road Master EZ5 base plate. This one is a little different than the MX series I had on my last 2 door wrangler. There seems to be more movement in the mounting arms. This was one of the reasons why I decided to "gopro" the action. I cannot make out the movement as well on the rear view camera.
THe EZ5 uses these removable arms that simply twist lock into place. My old MX series used the pins and I could lock them on. However the EZ5 was easier to install IMHO as I did not have to remove the bumper to do so or even drill any holes. The only thing I had to do was trim out some of the lower air dam.
