Dale_Traveling
Mar 25, 2015Explorer II
debaets wrote:Diodes will prevent the feed back but the switch would work also.
,,, If your jeep brake pedal is activating your jeep brake lights you may be back feeding your MH lights and cancelling your turn signal lights.
The other problem to watch for is the toad brakes can cancel the turn signal on the toad. The coach signal combines brakes and turn signals so even with the brakes on the light will still flash. Using additional bulbs will work around both problems or you can use a two wire to three wire convertor such as one of THESE. Ran into the problem with the new toad, Honda CRV.
Also AMAZON now carried NSA Products.
