holstein13
Mar 25, 2015Explorer II
mowermech wrote:Thanks, I guess I should have also mentioned that I had the braking system as well. I just moved the tow bar and braking system over from my old car to the pickup truck and purchased a new base plate that I would have needed anyway. It was cheaper than getting a new Ready Brake system. My current system is very easy to use as it's permanently installed in the engine compartment on the power brakes. In fact, it's one less cable to hook up than the ready brake, but I like the simplicity and beautiful solution of the Ready Brake better than my separate air braking system that could malfunction.holstein13 wrote:
What a clever way to show the effectiveness of this braking solution. I really like this system and would have purchased it for my current rig had I not already owned the Blue Ox tow bar.
There are two systems available.
The Ready Brute is the towbar and braking system combination, as shown.
The Ready Brake is the braking system only, that can be used with ANY towbar (including your blue Ox unit).
Then there is the Ready Stop add-on that gives braking if the toad should ever break away from the towing vehicle.
full information is on the NSA website.
