JetAonly
May 15, 2015Explorer
chadk66 wrote:
A set of 100 hp injectors for older cummins is roughly $300 after returning cores. Methanol injection is el cheapo. You use windshield washer fluid and small amounts.
If your experience is PU's then then the duty cycle is very different for a MH. PU might run at 20% power while the MH in cruise could be well above 50%. I't not just gross weight but the drag rise is huge. Have you seen the CAT document on Power required?
