BobGed
May 19, 2016Explorer
DANO2014 wrote:
As the time rolls forward.... For more info, I
purchased this Allegro Bus 2002 about 5 years
ago.
I have not had any issues on the lights
of this coach. I wanted to install LED bulbs on the
Rear and during this procedure is when I
noticed the Amber lights were the turn signal
which is OK but to my surprise the break lights
were on the same? I have checked with the
previous owner and to his knowledge it was
purchased new as is and was not aware of the
Config of the lights.
There is nothing wrong, all lights are working
except not by the way the LAW !
I cannot just change my Lens around which
would be a very simple fix but no doubt some
wires will have to be move around in order for
this to work properly. I will make another attempt
tomorrow with a little help, if that doesn't work
I will take it to a PRO ?
Thanks all for you help & appreciate reading
your responses....I won't give up too easy!
I would suggest you call Don Boyd at Tiffin in Red Bay (256) 356-0261 Ext 3824.
38,782 PostsLatest Activity: Aug 31, 2026
