gbopp
Nov 23, 2015Explorer
Definitely tarp it if you can't get the Allegro under a roof. Secure the tarp so the wind doesn't remove it.
Follow the advice given above.
After you get it cleaned and repaired, you may want to consider a pressure check to make sure you fixed the leak.
Also, you may want to run a dehumidifier in your Allegro to help remove the interior moisture.
38,769 PostsLatest Activity: Mar 31, 2026
