Gjac
Nov 23, 2015Explorer III
Ken,I would scrape away all of the sealant, remove the vinyl bead from the track and you will probably see rusted screws underneath. Once you remove the screws you can lift the EPDM rubber and see how bad the wood damage is underneath the roof. Replace the wood if necessary if not too bad just let it dry out real good. I would bond the rubber roof to the wood before screwing the metal strip back down and replacing the vinyl insert.You will most likely need new screws. Then seal it real good with caulking or Eternabod tape. Good luck and let us know how you make out.
38,769 PostsLatest Activity: Mar 31, 2026
