warcraftjunkie1
Mar 19, 2015Explorer
Jim Shoe wrote:
Rusted screws means water. Until you find and fix the source of the leak(s), you'll just have to do it again and again. The first place I'd look is around the marker lights. The factories install them with power screwdrivers.
I have found the sources of leaks... yes, multiple. Lower right sill of the front window. I'll be subtracting that front facing window when I re-skin her.
Looks like the marker lights on the top were surprisingly good.
The seam at the top where the roof line meets the side panel on both sides developed leaks. When sealing her back up that will be addressed. I've taken out any of the bad wood, styrofoam, and buffed up the steel tubing to remove the rust as well as applied a rust inhibitor to the steel.
