rjstractor
Apr 21, 2021Nomad
Grit dog wrote:
You can have basically any Ford E series converted to 4wd. Not cheap but likely not more than buying one. Guessing $20k for a conversion?
Super Cs can be had in 4wd. Again, even the decent used ones are $100k or more.
Normal rwd dually C with the right tires all around. Think studded snows or siped, studded mudders will be quite capable. Although the last part of the run up to Crystal can be a bobsled run coming down.
Easiest and most versatile solution if 4wd is a must is pickup truck and a TC.
Add Tigers and any of the other small time overland type rigs, but none are cheap unless old and clapped out.
Agree with Grit if you just plan on running up to Crystal or Snoqualmie. Not exactly apples to apples, but where I work we run studs all around in the winter on our E450 aid cars. Granted we don't get alot of snow around here, but when we do the roads get pretty snotty. The fire department doesn't have snow days, and with those studs the E450 will go up and down pretty much any hill, including unplowed driveways. A motorhome has 2/3 of its weight over the rear wheels so traction is surprisingly good.
38,782 PostsLatest Activity: Sep 02, 2026
