dshinnick wrote:
Hey all-
We have a 2005 Holiday Rambler Ambassador. We left it in storage, completely unhooked from everything, for just over three weeks. I left the refrigerator ON, running on LP, not realizing that it requires charged-up house batteries to operate. And, I forgot to use the battery disconnect, so when we got back, the house batteries were dead and nothing 12 volt was working, including the refrigerator. I first hooked up to shore power; then, probably 10 minutes later, I figured the battery acid level was probably low, and was it ever. Maybe completely dry, I don't know. But, I filled them all up. The EMS started bulk charging the batteries (though I guess it would have started when I went on shore power, before I filled the water back up). As of right now, about an hour after getting back, it's still bulk charging, and showing 13.4 volts.
The refrigerator has shown no signs of life at all. While working outside I noticed a red glow coming from the outside refrigerator compartment. I have had the Norcold recall/fix done, and the red light on the little plastic box they installed as part of the fix, is on.
There is a "refer" fuse in the front distribution panel, which I assume is for the refrigerator; it's good.
So, I'd be interested in your thoughts on this. I'm thinking that I may have fried the house batteries, but I can't see why the refrigerator would be damaged. It just...shut off, right? We're parked on the level, so I don't see that as a problem.
Anyway, how to proceed from here? What to watch for? Any risk (of fire or damage) to let the batteries keep on bulk charging? Anything I can do for the fridge? I'm guessing that the red light outside is some kind of warning light, but I don't know what to do about it.
Thoughts Welcome-
Thanks!
Dave
Did I miss it somewhere or are you saying that the fridge won't run on 120vac either? If it just ran out of gas, the lines are surely full of air and will take some doing before it's all out of there. I'd start with lighting the range to be sure that you have gas in that area.
