Dutch_12078
Sep 03, 2019Explorer III
4x4van wrote:
I always get a chuckle when I see these posts; and the extents that some will go to to put water into their tank. If your RV has a winterizing valve, then you already have everything you need. Simply turn your City/Fill valve to "Fill", and turn your winterizing valve to "winterize". Drop the winterizing line into a bucket of water and turn on your water pump. Your onboard pump will draw the water into the lines and then push into the freshwater tank. Refill bucket as needed.
Yep, that's what I had on our previous motorhome, but not on the current one. So I added it...
- TreknladyApr 14, 2025Explorer
On a 2018 Thor Four Winds Class C, it has a gravity fill for the onboard tank but no sign of a diverter valve option. Yet the onboard tank filled itself and is overflowing. Had to shut off the city water at the post and start using up the tank water via the water pump.
Where is the diverter valve that us allowing the water to fill the on board tank???!- way2rollApr 15, 2025Trailblazer
You're responding to a 6 year old topic. You may want to start a new topic with your question as it's likely to get more responses than buried in a very old one.
38,782 PostsLatest Activity: Aug 31, 2026
