DrewE
Oct 02, 2020Explorer III
Heat buildup from the Reflectix won't be any problem at all. Heating glass leads to cracking mainly if it's not even, or if the glass is mounted in such a way that it cannot expand or contract sufficiently to take up the stresses; and in any case, the Reflectix won't cause the glass to be noticeably warmer than if the window were covered with, say, a typical curtain.
If the window in question is an emergency exit window, you oughtn't block it such that you cannot escape quickly in the event of a fire or similar problem.
38,782 PostsLatest Activity: Sep 10, 2026
