coolmom42
Oct 02, 2020Explorer II
DrewE wrote:
Heat buildup from the Reflectix won't be any problem at all. Heating glass leads to cracking mainly if it's not even, or if the glass is mounted in such a way that it cannot expand or contract sufficiently to take up the stresses; and in any case, the Reflectix won't cause the glass to be noticeably warmer than if the window were covered with, say, a typical curtain.
If the window in question is an emergency exit window, you oughtn't block it such that you cannot escape quickly in the event of a fire or similar problem.
Thanks!
The exit window is the other one beside the bed.
Why any builder thinks you need 2 huge windows by a bed, is beyond me.
38,782 PostsLatest Activity: Sep 10, 2026
